Marine Fuel Senders - 950 mm - £50 each (New)
Posted: Thu May 08, 2025 9:26 am
by NBF
The KUS single station level sender is European resistance and suitable for use in diesel or petrol (gasoline) fuel tanks and water tanks. The 950mm dip level sender features a stainless steel 316 body, a 2mm thick NBR rubber gasket, 5 x M5 Screws, and a PVC covered wire. Sender uses magnetic field to control the on-off switch and features a long service life and vibration protection. The sender has a protection rating of IP67.
Single station level sender is suitable for operating one gauge, for dual gauge operations order a dual station level sender.
- Resistance Output: 0 to 190 ohms
- Power Rating: 125mW
- Resolution range: 10mm to 40mm
- KUS Part Number: JS60074 / S5-E950
When fitting this sender you may also need the JS21880 SAE 5 flange (sold separately) depending on your application.
