This pump is unboxed but never used or even fitted.
It's £240 at ASAP Supplies so grab yourself a bargain.
Collection Wayford Bridge NR12 or can dispatch by Royal Mail.
Specifications.
Approvals CE Listed, Ignition Protected 8846, Thermally Protected, IMCI Certified
Flow Rate Description 49 LPM (13 US GPM)
Fuse 15A Maximum
Height Description 96mm (3.8")
Length 275mm (10.8")
Outlet Left Hand 25mm (1") ID Hose
Voltage Description 12V DC
Width 125mm (4.9")
Brand SHURflo
Warranty 3 Years
Hose Size 25mm / 1", 38mm / 1-1/2"
Model 3200-001
Replaces Closest Alternative For: 509552 - SHURflo Macerator Pump (3200-100)
Inlet Outlet Inlet 38mm (1-1/2") Barb / 1-1/2" NPT
SUREFLOW Macerator Sanitation Pump - £200
- Attachments
- IMG_20250804_124801_547.jpg (2.67 MiB) Viewed 6209 times
- IMG_20250804_124755_017.jpg (1.85 MiB) Viewed 6209 times
