Marine Fuel Senders - 950 mm - £50 each (New)
The KUS single station level sender is European resistance and suitable for use in diesel or petrol (gasoline) fuel tanks and water tanks. The 950mm dip level sender features a stainless steel 316 body, a 2mm thick NBR rubber gasket, 5 x M5 Screws, and a PVC covered wire. Sender uses magnetic field to control the on-off switch and features a long service life and vibration protection. The sender has a protection rating of IP67.
Single station level sender is suitable for operating one gauge, for dual gauge operations order a dual station level sender.
- Resistance Output: 0 to 190 ohms
- Power Rating: 125mW
- Resolution range: 10mm to 40mm
- KUS Part Number: JS60074 / S5-E950
When fitting this sender you may also need the JS21880 SAE 5 flange (sold separately) depending on your application.
