Hard bottom Plastimo inflatable dinghy open for offers as need a repair to inner bow seam and will hold air for two/three hours. It has two inner tubes and it is the port one that is leaking.
Hard transom with outboard bracket, garboard drain and two U-boats.
Has had repairs done to the base.
The air pump is included.
Plastimo Inflatable Dinghy Rib (No longer available)
- Attachments
- IMG_20240316_113817_061_copy_2080x1560.jpg (280.67 KiB) Viewed 22243 times
- IMG_20240316_113755_283_copy_2080x1560.jpg (450.26 KiB) Viewed 22243 times
- IMG_20240316_113929_883_copy_2080x1560.jpg (415.33 KiB) Viewed 22243 times
- IMG_20240316_113747_468_copy_2080x1560.jpg (521.05 KiB) Viewed 22243 times
- IMG_20240316_113728_476_copy_2080x1560.jpg (674.97 KiB) Viewed 22243 times
