Click here for details!
https://amzn.to/47ej6sE
Unveiling the Secrets: Determining Propeller Taper for a Perfect Fit
Vlog series on Youtube
Today, I am here to guide you through the process of discovering the taper of your propeller, ensuring that you can effortlessly find the ideal replacement to snugly fit your prop shaft. Now, for those of us more accustomed to metric units, delving into the realm of Imperial measurements might seem like navigating a different language. Fear not, as I am about to demystify the calculations for you.
Understanding the Basics
To begin, you'll need the propeller you intend to replace. Focus on measuring the larger diameter because, bear in mind, the prop shaft is tapered. The dimensions of the larger end will be crucial in determining your prop shaft size. For instance, let's assume the larger end is one inch.
Proceed down to the tapered end, where the nut secures the propeller. Measure the diameter at this point. In our example, this measurement is thirteen-sixteenths of an inch. Now, calculate the difference between the larger and smaller ends. In this case, the difference is 3/16 of an inch.
Crunching the Numbers
Next, measure the boss, the part where the propeller is attached. For our demonstration, let's say this length is two and a quarter inches. Now, divide this length by the previously calculated difference between the two ends. In our scenario, it would be two and a quarter inches divided by 3/16 of an inch.
Breaking it down further, two and a quarter inches can be expressed as 30 to 36 sixteenths. Since we have a 3/16 difference, three goes into 36 twelve times. This calculation reveals that the taper, or the ratio from the larger end to the smaller end, is one in twelve.
So, there you have it—a straightforward method to determine the taper of your propeller. By following these steps and understanding the ratio, you can confidently choose the right size replacement for your prop shaft. Remember, precision is key when it comes to propellers, and this calculation ensures a perfect fit for optimal performance. Happy propeller replacement! #Norfolk #Broads
