    Advertising Is FREE On This Forum!
    You Can Support This Forum By Clicking The Advertisements.
Fitting Hinges On Boats.
Online
Post by Dances With Otters » June 28th, 2018, 9:54 pm
You may wonder what this has to do with boats but quite literally everything.
One thing I can almost guarantee you will need to replace on a boat at some time is hinges.
BEN
Re: Fitting Hinges On Boats.
Post by BEN » June 29th, 2018, 8:25 am
He'd get a clip round the ear at anywhere I was taught woodwork!!! using a hammer on a Chisel!!! he should use a mallet, less damaging for the chisel and less chance of wacking your hand. Important if you're working on a boat with idiots charging past...
Other than that it's easy on a bench, trying to get into some small awkward space on a boat is not so easy.. but the actual method, yes that's what I do...
