Woods End Staithe
General Norfolk Broads related posts.
Scardinus
Woods End Staithe
Post by Scardinus » January 6th, 2018, 6:49 pm
Went down to woods end Staithe a couple of weeks ago, which part if any are public, seemed to be a lot of no mooring and private signs, also very shallow, would it be the very small section on the right as you go in?
Re: Woods End Staithe
Post by Dances With Otters » January 6th, 2018, 7:18 pm
If you refer to the little place hidden on Barton? then yes, it is rather small but very handy to know. It is private behind that but turning there can be a bit tricky in low water.
I have not been there in ages.
It is marked on the Herbert Woods boat map, could be wrong but think it comes under Catfield. 🐈
Scardinus
Post by Scardinus » January 6th, 2018, 9:29 pm
Hit some branches or similar with the prop when I explored own there, only about 18" draft in the dingy, water was a horrible weak coffee colour, wouldn't like to see a 40ft hire craft attempt it!
Post by Dances With Otters » January 6th, 2018, 9:31 pm
Oh dear, that doesn't sound good. Perhaps with all the winds it's clogged up a bit
Post by David » January 7th, 2018, 5:19 pm
Was there earlier this year there is just enough room for a 27ft boat on the end the side mooring has a read cutters skif permanent moored on the side
Post by Dances With Otters » January 7th, 2018, 5:28 pm
Nice one.
I am glad it is mini size as otherwise it would be full.
I have never walked off the Staithe but apparently you can.
Post by David » January 7th, 2018, 5:46 pm
Yep you can walk past the rear of the houses and into Catfield
Post by Dances With Otters » January 7th, 2018, 5:53 pm
Bloody hell, did not know that. Probably a Tescos there too. ;)
