BMC 1500 CRANKSHAFT - Original MOWOG.
This was removed from a BMC marinised diesel engine on the Norfolk Broads.
It was a 1500 diesel.
The crankshaft was removed from a running engine which was removed to have a lighter smaller engine fitted in a sailboat.
I have many parts available.
The crankshaft shows signs of usage and will either need to be polished or reground.
The wear in my opinion is minimal.
This is an original MOWOG BMC part and is not an aftermarket patent part.
These engines were built by engineers and for engineers and personally I would not consider replacing a crankshaft on any BMC unless it was an original MOWOG quality product.
Item can be dispatched by courier or you can collect in person from the boatyard NR12 9LL.
