BMC 1.5 Diesel Engine & Borg Warner Gearbox.
This BMC 1500 diesel was removed from my sailboat as I wish to fit a smaller engine with two cylinders.
The BMC is a little too large for this boat although I used it quite successfully for over four years
It has been taken apart so it could be man handled off the boat as no crane could access where the boat is stored on dry standing.
Everything is there for the engine except the heat exchanger.
The engine is a runner.
It comes with a working Borg Warner Velvet Drive Gearbox and also all the bell housing and damper plate.
I also have a full gasket set which is still sealed.
Item is located on the Norfolk Broads.
All on a pallet if you wish to arrange collection through Pallet Line or similar. Last engine only cost £75 on a pallet so definitely feasible.
Viewing welcome.
