Boat Power Hook Up Cable - 10 Metres/2.5mm/16 Amp Arctic Cable.
This is professional and heavy duty 2.5mm arctic cable.
Other products are 1.5mm cable which is the incorrect cable gauge for these applications.
If you were to use 1.5mm cable for a boat/caravan power hook up, that is not a safe a electric hook up. Using a kettle or heater at the same time would draw too much current through the wire which is highly dangerous.
Don't just take our word for it - ask any qualified electrician.
Our power systems are made of 2.5mm Arctic cable.
They are 10 metres long.
Fitted with male and female sockets 16 amp.
We assemble these ourselves on the Norfolk Broads.
Just to put it into true perspective. Once these leads go over 35 metres in length, then the wire gauge should be increased to 4mm.
We believe in getting what you pay for. These power leads are the correct gauge, heavy duty and are not the unsafe 1.5mm versions.
Item will be dispatched by Hermes tracked delivery and is also available for collection at NR129LL.
Here are details about the Arctic cable used.
2.5mm
3 Core
240 Volt
Arctic Flex Blue
Cable. Length: 10m.
£30.00
Postage additional £5.50.
Re: Boat Power Hook Up Cable - 10 Metres/2.5mm/16 Amp Arctic Cable
Still have ten of these left and they are now reduced to £20 as need my car's front seat back...
Never Complain, Never Explain...
7 left and still £20.
