Don't waste your money buying premixed coolant.....you are paying a tenner for mostly water.
A product labelled coolant will be a pre-mixed, ready to use solution of Anti-freeze and water that you can pour straight into the cooling system. A product labelled antifreeze will be a concentrated solution, designed to be diluted with water before you add it to your cooling system.
