Winterising Boat Tips
Forum marine-related technical information. Not just Norfolk Broads boats but all vessels and help others to fix their boats.
The rivers have already started to freeze and if you haven't winterised your boat yet?..now is the time.
Don't waste your money buying premixed coolant.....you are paying a tenner for mostly water.
A product labelled coolant will be a pre-mixed, ready to use solution of Anti-freeze and water that you can pour straight into the cooling system. A product labelled antifreeze will be a concentrated solution, designed to be diluted with water before you add it to your cooling system.
winterizing.pdf
(920.86 KiB) Downloaded 18 times
