You rub it in basically and you just get the motion going. I rub that Farecla G3 compound in and then I come back with a little bit of water and good old fashioned elbow grease.
This section here in the photograph has been done and I think it is pretty obvious that it has made a big difference.
Restoring Inflatable Dinghy Appearance
Re: Restoring Inflatable Dinghy Appearance
- Attachments
- restoring dinghy15.jpg (6.11 KiB) Viewed 97 times
The Farecla G3, it has done wonders for the fibreglass hull. It has been a key component in restoring inflatable dinghy ribs, it is a must ingredient.
I would not say it is a hundred percent done yet as there are still some areas where I have missed.
Considering this has been done manually it has come up very good.
PVC is used in most production manufactured inflatable dinghy rib boats and there are several tests to check if you are unsure which fabric your inflatable dinghy or rib is made from.
Firstly, the back of the fabric if you can see the inside of the tube through the valve, Hypalon is dark grey or black on the inside.
PVC is the same colour on both sides.
It turns out the Cillit Bang is so good because it contains industrial strength cleaners and that explains a lot because it does a fantastic job on GRP too.
Restoring inflatable dinghy ribs is indeed possible without having to paint the whole boat. It is just one of those jobs that takes some time. A nice sunny weekend is all it takes at the very most.
If you have any questions at all? please feel free to register with my Norfolk Broads Forum and post your questions.
