Wayford Bridge Gets Damaged
Upload your photos of the Norfolk Broads.
Post by Dances With Otters » July 30th, 2018, 7:25 am
Looks like Wayford Bridge took a slap recently. :roll: :roll: :roll:
⛵ Euneda, Euneda Boat ⛵
JohnS
Re: Wayford Bridge Gets Damaged
Post by JohnS » July 31st, 2018, 11:17 pm
Isn't that boarding there to make both sides of the bridge the same height from the water? If it is they probably clouted the concrete on the other end :shock: :roll:
Post by Dances With Otters » August 1st, 2018, 5:35 am
The bridge is on a corner with a camber, so they must have banged all the way along.
7.5 feet at the moment, so they must have thought the signs for bridge clearance in the cabin refer to something else.
Post by David » August 1st, 2018, 11:49 am
Saw a Richo's boat stuck under there about 8 weeks ago the Broads Authority were there to
