Sailing Boat Terminology?
High Seas
Post by High Seas » June 19th, 2017, 4:07 pm
Does anyone know the correct name for this part on my masthead please?
The steel wire shrouds are attached to it by an eye/thimble.
Re: Sailing Boat Terminology?
Post by David » June 19th, 2017, 7:43 pm
Hi my sailing parts terminology is a bit sparse but is that not a compression tube?
High Seas
Post by High Seas » June 20th, 2017, 10:38 am
I don't think so, they usually have tangs on the ends.
This one sits through the mast rather like a compression tube but the eyelets on the shrouds actually go around the tube.
I thought if I could identify this part then I may be able to identify the manufacturer of my mast.
I also would like to see a similar set up as I am having issues with the steel wire rope of the stays brushing against the inner walls of the mast which is damaging the wires.
Post by David » June 20th, 2017, 1:45 pm
Your cables that attach to that tube I am assuming has a swaged eyelet and that tube passes through them, do those wire cables then run back to chain plates on the boat
High Seas
Post by High Seas » June 21st, 2017, 9:03 am
Yes that is right.
Post by David » June 21st, 2017, 6:32 pm
How far down the mast do they exit from the top anchor point, I am assuming that there is also front and back stays also, and how are they mounted on your mast?
High Seas
Post by High Seas » June 22nd, 2017, 10:11 am
If you look at the above photo you will see a white cable coming out, the upper shrouds share that exist hole.
I am trying to contact the chap who built the boat as for the life of me I can not find a similar set up on Google.
The two lower shrouds work by the same process and go internally in to another aluminium pole/tube which also forms part of the spreaders.
I suspect this type of set up was chosen because it is a folding mast and the aluminium tubes rotate as the mast is lowered or raised.
I really would to find a similar set up just to make sure everything is as it should be as the whole rigging is going to cost me a few bucks. In fact a small fortune.
High Seas
Post by High Seas » June 22nd, 2017, 10:19 am
You can actually see where the rigging wire has rubbed up against the mast.
